Hi David,
Your soft limits are set of 1 billion counts could you be
moving that far. Consider setting to 1e30 and -1e30
instead.
Normally that would send a Soft Limit Error and feed hold to
a stop and not disable axes.
Which axes are disabled?
I assume this is the axis configuration for your Spindle?
What are your spindle programs doing?
You might search all your programs (and included files) for
the word "Result"
One of my machines has started giving a gcode fault
due to a disabled axis. The axis is an open loop
step/direction one which feeds a C6 card for speed
control of a VFD. The M3, M5 and S commands use the
CSS Spindle Using Jogs programs and I can't seem to
find why the axis would disable.
Here are the settings for the axis...
ch4->InputMode=NO_INPUT_MODE;
ch4->OutputMode=STEP_DIR_MODE;
ch4->Vel=40000000;
ch4->Accel=400000;
ch4->Jerk=4e+006;
ch4->P=0.2;
ch4->I=0;
ch4->D=0;
ch4->FFAccel=0;
ch4->FFVel=0;
ch4->MaxI=200;
ch4->MaxErr=20000;
ch4->MaxOutput=200;
ch4->DeadBandGain=1;
ch4->DeadBandRange=0;
ch4->InputChan0=4;
ch4->InputChan1=1;
ch4->OutputChan0=14;
ch4->OutputChan1=1;
ch4->MasterAxis=-1;
ch4->LimitSwitchOptions=0x100;
ch4->LimitSwitchNegBit=0;
ch4->LimitSwitchPosBit=0;
ch4->SoftLimitPos=1e+009;
ch4->SoftLimitNeg=-1e+009;
ch4->InputGain0=1;
ch4->InputGain1=1;
ch4->InputOffset0=0;
ch4->InputOffset1=0;
ch4->OutputGain=1;
ch4->OutputOffset=0;
ch4->SlaveGain=1;
ch4->BacklashMode=BACKLASH_OFF;
ch4->BacklashAmount=0;
ch4->BacklashRate=0;
ch4->invDistPerCycle=1;
ch4->Lead=0;
ch4->MaxFollowingError=10000000;
ch4->StepperAmplitude=250;
ch4->iir[0].B0=1;
ch4->iir[0].B1=0;
ch4->iir[0].B2=0;
ch4->iir[0].A1=0;
ch4->iir[0].A2=0;
ch4->iir[1].B0=1;
ch4->iir[1].B1=0;
ch4->iir[1].B2=0;
ch4->iir[1].A1=0;
ch4->iir[1].A2=0;
ch4->iir[2].B0=1;
ch4->iir[2].B1=0;
ch4->iir[2].B2=0;
ch4->iir[2].A1=0;
ch4->iir[2].A2=0;
Is it possible that because this axis only moves in 1
direction that the movement over several hundred parts
is putting the soft limits at the max? The only thing
in the console window that looked like it might be an
error was Result=0. I couldn't find this reference in
any of the CSS programs.
Thanks in advance,
David.
